Exploring Smart Lighting Solutions with Hue Dimmer Switch
I’ve been diving into the world of smart lighting lately, and I’m absolutely thrilled with how it’s transforming my home. One of the most exciting projects I’ve undertaken is setting up a series of light scenes in my daughter’s room using a Hue Dimmer Switch. It’s been a bit of a learning curve, but the results are truly magical!
The idea was to create a seamless experience where pressing the power button on the Hue Dimmer Switch would cycle through different lighting scenarios. For example, the first press would turn on one bulb at a low dim level, the second press would add another bulb, and so on, until all three bulbs are fully illuminated. This gradual build-up of light is perfect for mornings, providing a gentle wake-up call.
However, I ran into a bit of a snag with the initial setup. Using Better Logic, I tried to increment a variable each time the power button was pressed and then trigger specific flows based on the variable’s value. While the logic seemed sound, it resulted in a bit of a lighting frenzy as all the previous states would activate simultaneously. It was like a light show gone wrong!
After some research and experimentation, I realized the issue was with how the variable was being handled. Instead of resetting the variable each time, it was accumulating previous states, causing the unexpected behavior. To fix this, I adjusted the logic to reset the variable after each press, ensuring only the current state is active. This simple tweak made all the difference, and now the system works like a charm!
I’d love to hear from others who have tackled similar projects. Have you found innovative ways to use smart switches for complex scenes? Any tips or tricks to share would be invaluable. Let’s keep the creativity flowing!
Cheers,
Andreas
