Exploring Smart Lighting with Fibaro Dimmers and RCCB Compatibility
Hello fellow smart home enthusiasts! I’ve been diving into the world of smart lighting lately and thought I’d share my experience, especially since it might be helpful for others exploring similar setups.
I recently upgraded my home’s electrical system to meet current UK building regulations, which involved installing a new fusebox equipped with RCCBs (Residual Current Circuit Breakers). These devices are fantastic for safety, as they detect even the slightest imbalance in current flow and cut the power to prevent hazards. However, this upgrade raised a question about compatibility with my existing Fibaro Dimmer 2 units.
I currently have these dimmers installed behind light switches, and they rely on a clever trick where they draw a small amount of current to power themselves through the earth wire. This setup has been working beautifully, but I was concerned it might cause issues with the new RCCBs, which are designed to trip at just 30mA of imbalance. My fear was that the dimmers might inadvertently trigger the RCCB, leading to unexpected power cuts.
After some research and reaching out to the community, I discovered that while there are potential risks, there are also solutions. Many users have successfully integrated Fibaro dimmers with RCCBs without issues, especially if the wiring adheres to modern standards. However, if the wiring doesn’t include a neutral wire at the switch point (which is common in older setups), it’s crucial to ensure that the dimmer’s power draw doesn’t exceed the RCCB’s threshold.
For those in a similar situation, here are a few tips I’ve gathered:
  • Check Your Wiring: If possible, bringing the neutral wire to the switch point is the most reliable solution. It allows the dimmer to draw power without relying on earth leakage, which can be a safer and more efficient setup.
  • Test Before Full Installation: If rewiring isn’t feasible, consider testing the dimmers with the new fusebox installed to see if they cause any issues. This way, you can address problems early without disrupting your entire setup.
  • Consult Manufacturer Guidelines: Fibaro provides detailed guidelines on installing their dimmers in various configurations. Reviewing these can offer peace of mind and ensure your setup is as safe as possible.
It’s been a fascinating journey learning about the nuances of smart lighting and electrical safety. I’m relieved that with a bit of planning and community support, I can enjoy both the convenience of smart dimmers and the safety of modern RCCBs. If anyone has additional insights or experiences to share, I’d love to hear them!
Cheers to smarter, safer homes! :star2:
