I’ve been diving into the world of smart home automation, and one thing I’m really excited about is finding the perfect switches to control my lights. I’ve got a setup where most of my lamps are plugged into outlets controlled by wall switches, and I want to add some smart automation without losing the ability to toggle them manually.
I came across the Zooz dimmer switch, which seems like a great option since it supports both manual control and smart features. However, I ran into a bit of a snag when I found out that using these switches with switched receptacles isn’t recommended. Zooz mentioned that their switches are rated for lighting loads only, and using them with other devices like heaters or vacuums could cause issues. While I only plan to use them for lamps, I’m still a bit concerned about someone accidentally plugging in something else.
I reached out to Zooz for clarification, and they suggested using the bottom switch of a double switch model. But here’s the catch—it doesn’t work in a 3-way setup, which is something I really need for my home. I’m hoping there’s a solution that allows me to keep the toggle style I love while ensuring everything runs smoothly.
I’ve also been looking into other brands like Jasco and some relay-based options. I’m curious if anyone has experience with these and if they handle switched receptacles better. It would be amazing to hear about any successful setups or tips for integrating different brands seamlessly.
On a lighter note, I’ve been experimenting with automating my lighting scenes using Google WiFi. It’s been a bit of a learning curve, but seeing everything come together is so rewarding. I’d love to hear about others’ experiences with mesh networks and how they’ve optimized their setups for reliability and performance.
Overall, I’m excited to continue exploring these options and finding the perfect balance between manual control and smart automation. If anyone has insights or recommendations, I’d be thrilled to hear them!
