Hi everyone, I’ve been diving into the world of smart home technology lately, and I wanted to share some of my experiences and insights. Whether you’re a seasoned pro or just starting out, I hope this post can offer some value or spark a discussion!
First, let’s talk about smart thermostats. I’ve been experimenting with adding smart TRVs (Thermostatic Radiator Valves) to my radiators, and it’s been a fascinating journey. I have two bedrooms with very different heat requirements—one south-facing that gets extremely hot, and another north-facing that struggles to stay warm. Initially, I was a bit confused about how these TRVs would interact with each other and the boiler. Would they be calling the boiler independently, potentially causing it to cycle on and off frequently? That’s something I wanted to avoid, especially since my boiler is quite noisy.
After some research and trial and error, I found that integrating smart thermostats with the TRVs can provide a more efficient and coordinated system. The smart thermostat acts as the master device, determining when heat is needed based on the set temperature, and then signals the TRVs to adjust accordingly. This setup not only reduces the boiler’s on/off cycles but also ensures that each room maintains its desired temperature without unnecessary heating.
Another area I’ve been exploring is Firmware Over-The-Air (FOTA) updates, particularly for custom boards. I’ve successfully implemented FOTA on my development board using Nordic’s nRF Connect SDK, but when I tried to port this to a custom board, I ran into some issues. The main problem seemed to be related to device tree configurations and SPI flash settings. After some troubleshooting and consulting the Nordic forums, I realized that the custom board’s device tree wasn’t properly configured for FOTA. I ended up having to adjust the SPI flash settings and ensure that all necessary device tree nodes were included. It was a bit of a learning curve, but it taught me the importance of thorough device tree configuration when working with custom hardware.
On the software side, I’ve also been playing around with Home Assistant to integrate all these devices seamlessly. Setting up automations based on temperature sensors and time schedules has been incredibly rewarding. For instance, I now have my lights and heating adjust automatically based on my daily routine, which not only enhances comfort but also helps with energy efficiency.
One thing I’d love to hear more about from the community is experiences with different smart thermostat brands and their compatibility with various heating systems. Have you found any particular brand that stands out for its reliability and integration capabilities? Also, if anyone has tips on optimizing FOTA updates for custom hardware, I’d be grateful to hear them!
In conclusion, whether you’re tweaking your heating system, experimenting with custom hardware, or diving into home automation, there’s always something new to learn and explore in the smart home space. I’m excited to continue this journey and can’t wait to see what innovations the future holds!
Happy tinkering! ![]()
