Exploring the Integration of Victron Venus OS with Home Assistant
As a home automation enthusiast, I’ve been diving into integrating my Victron Venus OS system with Home Assistant. It’s been a fascinating journey, though not without its hurdles. I stumbled upon a helpful blog that detailed setting up an MQTT bridge between Victron and Home Assistant, which seemed like the perfect solution. However, navigating the configuration files proved a bit tricky, especially with the newer versions of Home Assistant.After some research, I realized that locating the Mosquitto configuration file wasn’t as straightforward as the tutorial suggested. I spent quite a bit of time tweaking settings and cross-referencing forums to ensure everything was aligned correctly. The sense of accomplishment when the integration finally worked seamlessly was immense!For anyone looking to undertake a similar project, I’d recommend thoroughly checking your Home Assistant version and ensuring all paths and configurations align with the latest documentation. Also, don’t hesitate to reach out to the community for support—it’s a wealth of knowledge and camaraderie. Happy automating! :rocket:
