Hey everyone! I’ve been diving into the world of smart home automation lately, and I’ve got to say, it’s been an absolute thrill. I recently decided to tackle a project that’s been on my mind for a while: integrating my Somfy RTS roller shutters with ESPHome using a Wemos D1 Mini and a 433.42 MHz RF transmitter. The goal? To have seamless control over my shutters right from my Home Assistant setup. Let me walk you through my journey so far and maybe pick up a few tips or tricks along the way!
First off, I’ve got to admit, I was a bit nervous diving into this project. I’ve used ESPHome before, but integrating Somfy RTS was new territory for me. I started by researching existing solutions and found a few GitHub repositories that seemed promising. One in particular, dmslabsbr/esphome-somfy, caught my eye because it looked like it was specifically designed for this kind of setup. I decided to give it a shot.
The hardware setup wasn’t too bad. I connected the RF transmitter to D6 and the receiver to D5 on my Wemos D1 Mini. I made sure to replace the crystal on the RF module with a 433.42 MHz one to ensure compatibility. I followed the instructions in the GitHub repo to the letter, copying the necessary files into my ESPHome directory. Everything seemed to be going smoothly until I tried compiling the code.
That’s when the fun began. I encountered a few errors that I wasn’t quite sure how to handle. The first issue was with the Ticker.h file, which the compiler couldn’t find. After some quick research, I realized that I needed to include the Ticker library in my project. I added it to my includes section, and that seemed to fix the problem.
Next up was the SPIFF deprecation warning. I wasn’t entirely sure what that meant, but I did some digging and found out that SPIFFS is being phased out in favor of LittleFS. I decided to leave it for now since the deprecated functionality still worked, but I made a mental note to update my code once I’m more comfortable with the setup.
Finally, I ran into some issues with the YAML configuration. I had to tweak a few things, like removing the commented-out arduino_version line, which was causing errors. After a bit of trial and error, I managed to get everything compiling successfully. The logger didn’t show any critical errors, which was a huge relief!
Now, onto the testing phase. I set up three virtual covers in ESPHome, each representing one of my shutters. I assigned different rolling codes to each one and made sure they were properly registered in the system. The best part? It actually worked! I could control my shutters from the Home Assistant dashboard, and the statuses updated in real-time. It was such a satisfying feeling to see everything come together.
Of course, there’s always room for improvement. I’d like to explore the possibility of reading existing remote codes to make the setup even smoother. I also want to look into using LittleFS instead of SPIFFS once I get more comfortable with the project. For now, though, I’m thrilled with the results.
If anyone out there has experience with integrating Somfy RTS or has any tips for improving my setup, I’d love to hear from you! The more we share our experiences, the better we all get. Happy automating, everyone! ![]()
