Exploring the Potential of Hue Bridge v2 for Long Transition Times
Hi everyone, I’m really excited to share my recent exploration with the Hue Bridge v2 and its capabilities for long transition times. I’ve been experimenting with creating smooth, gradual lighting effects in my home, and I stumbled upon an interesting challenge that I thought I’d document here.
So, the goal was to set up a scene transition that lasts longer than the default 10-minute limit. I came across the Hue Bridge v2’s transition time settings and noticed that it’s capped at 600 seconds (10 minutes). I was curious why this limit exists, especially since the Hue v2 API supports up to 6 hours in milliseconds. After digging through some GitHub repositories and developer documentation, it seems like the limit is intentionally set to 600 seconds in the Home Assistant integration.
I decided to test this by modifying my automation rules. Here’s a snippet of what I tried:
yaml
alias: test
trigger:
  • platform: time
    at: “06:00:00”
    action:
  • service: hue.activate_scene
    data:
    transition: 1200
    target:
    entity_id: scene.myroom_honolulu
    mode: single
Unfortunately, this resulted in an error: value must be at most 600 for dictionary value @ data['transition']. It seems like the integration strictly enforces this limit, which is a bit frustrating for those of us looking to create more immersive lighting experiences.
I reached out to the community and found that others have encountered similar limitations. Some suggested that this might be a safeguard to prevent overly long transitions from causing performance issues or interfering with other automation tasks. While I understand the reasoning, I still wish there was a way to bypass this limit for specific use cases.
On a positive note, I discovered that the Hue v2 API does allow for much longer transitions, so there might be potential for future updates to the integration to lift this cap. In the meantime, I’m exploring alternative methods, such as using multiple scenes or scripts to simulate longer transitions indirectly.
This journey has been a great learning experience, and I’m grateful for the supportive community here. If anyone has insights or workarounds for this limitation, I’d love to hear about them! Let’s continue pushing the boundaries of what’s possible with smart lighting.
Cheers,
