I’ve been diving into the world of smart home automation with OpenHAB, and I must say, it’s been an incredible journey! One of the most fascinating aspects I’ve encountered is the KNX2 binding, which has allowed me to integrate various smart devices seamlessly into my setup. However, as I started experimenting with different configurations, I stumbled upon an interesting issue that I thought might be worth sharing with the community.
A few days ago, I decided to reconfigure my rollershutter actuators using the KNX2 binding. Initially, everything seemed to work smoothly—commands were being sent, and the actuators responded as expected. But then, after a short period, I noticed that the rollershutters would stop responding, even when triggered by a wall switch. This was puzzling, especially since replacing the actuators didn’t resolve the issue.
After some research and troubleshooting, I discovered that changing the hardware address of the actuators to something other than their default settings seemed to eliminate the problem. It appears that the KNX2 binding might be pulling data from the actuators at an increasing frequency, which could be causing the devices to malfunction. I’m curious to know if others have experienced similar behavior or if there’s a known workaround for this.
This experience has been both challenging and enlightening. It’s reminded me of the importance of thorough testing and configuration when working with smart home systems. I’m looking forward to hearing from others who might have insights or solutions to share. Happy automating! ![]()
