I’ve recently been exploring ways to integrate my pool maintenance into my smart home setup. My goal is to make my dumb pool robot, a Maytronics Dolphin, smarter by adding some tech to it. I’ve come across some interesting ideas on forums and Arduino communities that could potentially turn this into a reality. Here’s what I’m thinking about and where I need some help.
First, I’ve read that replacing the existing electronics with an Arduino board could allow me to control the robot’s movements via a pre-recorded pattern. This would mean the robot could move forward, turn, and adjust its cleaning path without needing constant human intervention. The idea is to use an ESP32 module with esphome to send commands via Wi-Fi before submerging the robot in the pool. This way, the robot could operate autonomously, even without real-time connectivity.
Another intriguing concept I stumbled upon involves adding sensors like a radar or accelerometer to the robot. These sensors could help the robot map the pool’s layout or avoid collisions with the walls. Imagine the robot optimizing its cleaning path based on the pool’s geometry—this could significantly reduce cleaning time and make the process more efficient. I’ve seen similar projects on Arduino forums where users modified boats to navigate pools autonomously, and I’m curious if this approach could work for pool robots too.
However, I’m not very familiar with ESP32 or esphome, so I’m a bit stuck on how to implement these ideas. I’m wondering if there’s a community or project that has already tackled this or if someone with more experience could guide me through the process. I’m also curious about the cost implications and whether this modification would be worth the effort compared to purchasing a newer, smarter pool robot.
If anyone has experience with similar projects or knows of resources that could help me get started, I’d greatly appreciate your insights. This seems like a fun and potentially rewarding project, and I’m excited to see if I can bring my pool maintenance into the smart home era!
