As a homeowner deeply interested in optimizing my smart home setup, I’ve been exploring the use of ultrasonic sensors for various applications. One particular area of interest is the HC-SR04 ultrasonic sensor in 3-wire mode. From what I’ve read, this setup can save valuable I/O pins, which is especially useful for devices with limited resources like the ATtiny85.
I’ve been considering integrating this sensor into my esphome configuration. My initial thought is to use it for distance sensing in my garage, where I could potentially automate lighting or door operations based on detected movement. Here’s a rough example of how I envision the configuration:
sensor:
- platform: ultrasonic
name: “Garage Distance Sensor”
trigger_pin: 26
echo_pin: 26
However, I’m still unclear about a few aspects. First, what unit does the sensor provide by default? Is it meters or centimeters? I’d love to confirm this to ensure accurate readings. Second, I’m curious about the reliability of the 3-wire mode in real-world applications. Have others successfully implemented this setup without encountering issues?
I’d also appreciate any tips on best practices for calibrating the sensor or integrating it with other home automation systems. Whether it’s for security, convenience, or just pure experimentation, I’m excited to see how this technology can enhance my smart home experience!
