Exploring the Potential of Virtual Door Sensors with Input Booleans
Hey community,
I’ve been diving into the world of smart home automation and thought I’d share my recent experience with creating a virtual door sensor using an input boolean. It’s been an interesting journey, and I hope my insights can help others who might be exploring similar setups.
So, my goal was to create a virtual door sensor that could mimic the behavior of a physical door sensor. I decided to use an input boolean as the foundation for this setup. Here’s how I approached it:
  1. Setting Up the Input Boolean:
    I started by defining an input boolean in my configuration:
    yaml
    input_boolean:
    chicken_door_input_boolean:
    icon: mdi:door
This creates a toggleable switch in the UI, which I can manually control to simulate the door’s state.
  1. Creating the Virtual Sensor:
    Next, I wanted to transform this input boolean into a sensor that other automations could react to. I used the template sensor platform for this:
    yaml
    sensor:
  • platform: template
    sensors:
    chicken_door_sensor:
    value_template: >
    {% if states.input_boolean.chicken_door_input_boolean == “on” %}
    open
    {% else %}
    closed
    {% endif %}
    friendly_name: ‘Chicken Door Sensor’
This sensor reads the state of the input boolean and outputs either “open” or “closed”.
  1. Testing the Setup:
    I toggled the input boolean to see if the sensor would update accordingly. Unfortunately, the sensor didn’t change its state as expected. I double-checked my configuration, and everything seemed correct. No logs were generated when I toggled the input boolean, which was puzzling.
  2. Seeking Solutions:
    I reached out to the community for help, and the response was incredible. Someone suggested checking the permissions and ensuring that the input boolean and sensor were in the same namespace. After verifying this, I realized that the issue might be with how the template sensor was processing the state changes.
  3. The Fix:
    A community member recommended using a different approach by leveraging the state attribute directly. I revised my sensor configuration to:
    yaml
    sensor:
    sensors:
    value_template: >
    {% if is_state(‘input_boolean.chicken_door_input_boolean’, ‘on’) %}
    open
    {% else %}
    closed
    {% endif %}
This change worked like a charm! The sensor now updates its state in real-time when the input boolean is toggled.
  1. Reflections and Next Steps:
    This experience taught me the importance of community support and the value of experimenting with different configurations. I’m now confident in using virtual sensors for more complex automations. My next project is to integrate this virtual door sensor into a comprehensive security system that includes notifications and alerts.
If anyone has tips or alternative methods for creating virtual sensors, I’d love to hear them! Thanks for being such a supportive community.
Best regards,
