I’ve been diving into some interesting challenges with my Wyze cameras lately, and I wanted to share my findings and experiences with the community. If you’re dealing with voltage drop issues, especially with longer USB extensions, this might be helpful!
I have a setup with several Wyze V2 and V3 cameras installed outdoors, and I’ve been using USB extension cables to connect them. While this works in theory, I noticed some frustrating issues, like the cameras locking up or losing connection. After some research and testing, I realized the problem was voltage drop—especially noticeable with longer cables and daisy-chained setups.
To tackle this, I decided to build a USB breakout box to measure the voltage and amperage at the camera end. The results were eye-opening. For example, a single V2 camera at the end of a 25ft extension cable showed a significant voltage drop, going from 5V to around 4.57V. When daisy-chaining two V2 cameras, the voltage dropped even further to 3.94V. This explained the instability I was experiencing!
I documented my findings in a YouTube video and shared some testing data. It’s been fascinating to see how small adjustments in cable length and setup can make a big difference. If you’re experiencing similar issues, I’d recommend checking your voltage levels and considering shorter cables or powered USB hubs for better performance.
This project has been a great learning experience, and I’m excited to see how others might approach similar challenges. If you’ve had success with voltage drop solutions, I’d love to hear about your setups in the comments below!
Happy tinkering! ![]()
