Exploring Wyze Robot Vacuum Firmware 1.6.113
Hello Wyze Robot Vacuum users, I’ve been following the recent updates to the Wyze Robot Vacuum firmware, specifically version 1.6.113, and I wanted to share my thoughts and experiences with this new release. The firmware update was released early this week and comes with some exciting improvements, particularly in the mapping algorithm. I’ve been using my Wyze Robot Vacuum for a while now, and I’ve noticed a few issues with mapping accuracy, so I was eager to try this update.
First, I’d like to highlight the key features introduced in this firmware version:
  1. Indicators for WiFi Connection and Firmware Update: This is a small but incredibly useful addition. Now, I can easily see when the robot is connecting to WiFi or updating its firmware, which adds a layer of transparency to the process.
  2. Optimized Mapping Algorithm: The Wyze team addressed some mapping issues where the map would occasionally rotate or overlap incorrectly after multiple runs. They identified that the LiDAR sensor’s cap pillars were causing data inaccuracies. The solution was to exclude these problematic data points, resulting in a more precise map.
  3. Improved WiFi Reconnection: The robot now reconnects to WiFi more reliably, which is a significant improvement for those of us who experience frequent disconnections.
I decided to test the new mapping algorithm by resetting my map and performing a quick mapping. The results were impressive. The map was cleaner, and the robot navigated more efficiently. However, I noticed that the initial mapping process took a bit longer than usual, which I assume is due to the improved data processing.
One thing I’d like to mention is the importance of following the instructions carefully when updating the firmware and resetting the map. I encountered a minor hiccup when I forgot to delete the old map data before starting the quick mapping, but once I did that, everything worked smoothly.
I also appreciate the detailed explanation provided by the Wyze team about the causes of the mapping issues and how they optimized the algorithm. It’s rare to see such transparency and technical depth from a manufacturer, and it really builds trust in the product.
If you haven’t tried the 1.6.113 firmware yet, I highly recommend updating your robot vacuum. The improvements are noticeable, and the robot feels more reliable and precise than ever before. I’m excited to see what other features and optimizations Wyze will introduce in future updates.
If anyone has encountered any issues or has feedback on the new firmware, I’d love to hear about your experiences in the comments below. Let’s keep the discussion going and help each other make the most out of our Wyze Robot Vacuums!
Cheers,
