Exploring Z2M Mesh Networks and Lighting Solutions
As someone relatively new to the world of Z2M, I’ve been diving into the fascinating world of mesh networks and smart home integration. Recently, I moved a bunch of Aqara sensors from their official hub to a SLZB coordinator, and it’s been quite the learning experience! My house is around 1900 sq ft, spread across three floors, and the SLZB coordinator is centrally located via PoE. I’ve also added 4x Sonoff S31 Lite plugs as routers to strengthen the network.
One thing I’ve been curious about is how the mesh network handles failures. If a single router goes down, will the sensors automatically switch to another router or the coordinator? I imagine that’s the whole point of a mesh network, but it’s good to confirm! On the other hand, if the coordinator itself goes down, I assume the entire Z2M setup would shut down, leaving the routers unable to function. That’s a critical point to consider for reliability.
I’ve also been experimenting with pairing strategies. I paired all my sensors to the router plugs, which are then connected to the coordinator. However, I noticed that the signal strength is often better when pairing sensors directly to the coordinator, even if the distance is similar or slightly farther. Does this mean I’m better off pairing everything directly to the coordinator, or is there a benefit to maintaining the mesh network structure despite the stronger LQI from the coordinator? It feels a bit like I’m investing in a mesh network without fully utilizing its potential.
Switching gears, I’ve been exploring lighting solutions for my new apartment, and I’m torn between different types of LED strips. I’ve seen some impressive examples at the Light Expo in Frankfurt, where vendors showcased LED strips with high CRI values that create a warm, natural light. I’m considering using RGBW or RGBWW strips for tunable white light, but I’m not sure if they can achieve the same level of natural light as dedicated tunable white systems. I’d love to hear others’ experiences with these setups!
Another topic I’ve been researching is the configuration of a DALI-based lighting system. I’ve seen recommendations for using a DALI controller, transformer, and ballasts for each LED strip, but I’m not entirely sure how to set this up properly. I’m also concerned about potential flicker at low light levels, especially with 1KHz PWM dimming. Is this a common issue, or is it something that can be mitigated with the right components?
Lastly, I’ve been experimenting with integrating my Sonos speakers through HomeKit using OpenHAB. While the integration works well for basic controls, I’m trying to figure out how to use Siri to control playlists or favorites directly. I’ve set up a rule with a switch accessory, but I’m running into syntax issues with the favorite commands. Any tips or examples would be greatly appreciated!
It’s been a whirlwind of learning and experimentation, but I’m excited to see how these different components come together to create a seamless smart home experience. If anyone has insights or advice on any of these topics, I’d love to hear them!
