Hey everyone, I’m diving into the world of Zigbee sensors and trying to integrate them seamlessly into my smart home setup. I recently came across an interesting challenge with my Zigbee door sensors. While they work perfectly on doors and windows, my fridge door sensor isn’t behaving as expected. I suspect the issue might be due to the steel in the fridge interfering with the sensor’s signal. Has anyone encountered a similar problem or found a solution that works around this? I’m curious if there are specific door sensors designed to handle such metallic surfaces without issues.
Another topic I’m exploring is setting up a secondary controller to improve connectivity in my large home. I have several thermostats and dimmers located in the basement and attic, which are far from my main HC2 controller. While I’ve tried using a larger antenna and range extenders, the response times are still inconsistent. I’m considering adding a secondary HCL to act as a master for these remotely located devices. However, I’m not entirely sure how to set this up or what the consequences might be. Any insights or experiences with secondary controllers would be greatly appreciated!
Lastly, I stumbled upon an interesting suggestion regarding automation time triggers. The idea is to add a random offset to the trigger time, say plus or minus 5 minutes, to make the house look more lived-in when away. This could be a fantastic feature for vacation modes. I’m wondering if anyone has implemented something similar or if there are any potential drawbacks to consider.
It’s always inspiring to see how others have tackled these challenges and integrated various devices into their smart homes. Looking forward to hearing your experiences and tips!
