As I embark on building my smart home ecosystem using Home Assistant, I’ve come across an intriguing challenge with Zigbee2MQTT. After setting up a Raspberry Pi 5 with Docker containers for various apps, including Zigbee2MQTT, I noticed an issue when integrating Home Assistant. Specifically, Zigbee2MQTT fails to execute LQI scans when Home Assistant is running, despite functioning perfectly otherwise. This has left me puzzled, as both apps are crucial to my setup.
I’ve spent considerable time troubleshooting, from reviewing logs to reinstalling containers, yet the issue persists. The logs indicate a failure during LQI execution when Home Assistant is active, but everything works smoothly when HA is shut down. This inconsistency is perplexing, especially since no other containers are affected.
While I’m relatively new to Home Assistant, I’m eager to understand the root cause. Perhaps there’s a conflict in resource allocation or a specific configuration tweak needed. I’d appreciate insights from the community on investigative steps or potential fixes. Meanwhile, I’m exploring alternative configurations and considering whether certain services might be interfering with Zigbee2MQTT’s operation.
This journey has been both challenging and enlightening, highlighting the importance of thorough testing and the value of community support in troubleshooting. I’m hopeful that with some guidance, I can resolve this issue and fully integrate Zigbee2MQTT into my Home Assistant setup.
