Exploring Zigbee2MQTT and HomeKit Integration Tips
Hello everyone, I wanted to share my recent experiences with setting up Zigbee2MQTT and integrating it with HomeKit. While the process has been mostly smooth, I’ve encountered a few hurdles that I thought might be helpful to discuss here.
Zigbee2MQTT Setup Challenges
I recently installed Zigbee2MQTT on my Proxmox server, but I ran into an issue where the service failed to start with the error message: “Error: Connection not initialized”. After some research, I realized the problem was related to the configuration of my Sonoff Zigbee 3.0 USB Dongle Plus. I had to ensure that the correct adapter type was specified in the config file and that the device permissions were properly set. Once I adjusted these settings, the service started without any issues!
HomeKit Integration Insights
Another area I’ve been exploring is integrating Zigbee devices with HomeKit. I’ve found that using HomeKit for automation is incredibly seamless, especially with devices like the Govee H5179 sensors. However, I noticed that the video feed from my Lorex doorbell via HomeKit had some lag. After some tweaking, I discovered that enabling hardware acceleration in Frigate and optimizing the camera settings significantly improved the performance. Now, the live feed is much smoother!
Tips for Others
If you’re setting up a similar system, here are a few tips I’ve gathered:
  • Always double-check your device permissions and configuration files.
  • For HomeKit integration, ensure your HA instance has sufficient resources, especially if you’re running it in a VM.
  • Don’t hesitate to experiment with different settings like hardware acceleration to optimize performance.
I’d love to hear from others who have successfully integrated Zigbee2MQTT with HomeKit or have tips for overcoming common setup challenges. Let’s continue to learn and grow together in this amazing community!
Best regards,
