Exploring Zigbee2MQTT and IKEA Devices Integration
Hey everyone, I’ve been diving into the world of Zigbee2MQTT and IKEA devices lately, and I wanted to share my experiences and some tips I’ve picked up along the way. :star2:
First off, I’ve been using Zigbee2MQTT with a Sonoff Zigbee stick, and it’s been a fantastic journey. I’ve managed to integrate various devices, including the IKEA Floalt panel and the TRADFRI remote control. Initially, I was a bit puzzled about how to set these up without relying on direct bindings, so I decided to tackle it through automation in Home Assistant. Here’s what I did:
  1. Device Naming in Zigbee2MQTT: I discovered that naming devices without spaces is crucial. Spaces can mess up MQTT topics, so I switched to using underscores instead. For example, my devices are now named Deckenlampe_Floalt and IKEA_FB_WZ. This small tweak made a big difference in ensuring smooth communication.
  2. Setting Up Automation: I created a helper list for color temperatures and set up individual automations for each button on the remote. It wasn’t the most elegant solution at first, but it got the job done. For instance, the middle button toggles the light, while the left and right buttons cycle through predefined color temperatures. I also adjusted the brightness using incremental steps, which made the experience much smoother.
Here’s a quick snippet of how I set up the toggle functionality:
yaml
alias: IKEA FB (toggle)
description: Switches the light via MQTT topic on toggle click
triggers:
  • topic: zigbee2mqtt/IKEA_FB_WZ/action
    payload: toggle
    trigger: mqtt
    conditions:
    actions:
  • target:
    entity_id: light.deckenlampe_floalt
    action: light.toggle
    mode: single
  1. Lessons Learned: One thing I learned is the importance of consistent naming conventions. It might seem minor, but it prevents a lot of headaches down the line. Also, while setting up each button individually was time-consuming, it gave me precise control over each function.
I’d love to hear how others have integrated IKEA devices with Zigbee2MQTT and Home Assistant. Have you found any shortcuts or tips that made the process easier? Let’s share and learn together! :rocket:
Cheers,
