I recently embarked on a DIY project to extend my Govee outdoor strip lights, and I wanted to share my experience and tips with the community. After purchasing the 98.4 kit, I wanted to create a bit more distance between the rolls on my roofline, specifically about 14 feet apart. Here’s how I approached it:
Understanding the Components: I carefully examined the wiring and identified the three wires inside the black casing. This step was crucial to ensure I knew what I was dealing with before making any cuts.
Splicing the Wires: I decided to splice the wires to extend the distance. I used a reliable soldering technique to connect the existing wires to a new 15-foot section. This allowed me to maintain the original connectors and achieve the desired gap without compromising the integrity of the system.
Testing the Setup: After completing the extension, I powered up the lights to test the new configuration. Everything worked perfectly, and the lights illuminated as expected. This gave me confidence that the DIY approach was successful.
Potential Issues and Solutions: I considered possible issues like voltage drop or connectivity problems but found that the extended setup performed well. Ensuring proper insulation and secure connections was key to avoiding any hiccups.
This project not only enhanced the aesthetics of my outdoor space but also gave me a sense of accomplishment. If anyone is considering a similar DIY extension, I highly recommend carefully planning the wiring and testing each component before final installation. Happy tinkering! ![]()
