Hi everyone, I wanted to share my experience with extending the Zigbee signal in my home and how I resolved some device issues. I’ve been using Zigbee devices for a while now, and while they’re fantastic, I’ve encountered a few challenges that I thought I’d document here in case it helps others.
The Issue with Range
One of the main problems I faced was that some of my Zigbee bulbs were too far from the gateway. This caused inconsistent control, especially with the Ikea Tradfri setup I have. I did some research and came across the idea of using a second-hand Philips Hue Bridge 1.0 to extend the network. I was a bit skeptical since most guides I saw were about the Hue Bridge 2.0, but it turns out the 1.0 model works perfectly with Home Assistant and Zigbee devices!
Setting Up the Hue Bridge
I connected the Hue Bridge to my existing Zigbee network through Home Assistant. The process was straightforward: I just needed to pair the bridge with my existing gateway. Once paired, it acted as a repeater, significantly boosting the signal strength in areas that were previously dead zones. This was a cost-effective solution, especially since I found a used Hue Bridge at a great price.
Fibaro Dimmer Issues
Another issue I encountered was with my Fibaro Dimmer 2 devices. For some reason, each dimmer created two light entities in Home Assistant—one functional and one non-functional. This was a bit confusing, especially when integrating with Google Assistant, as it showed both entities. After some digging, I found that this was due to the device reporting two different value instances. To fix this, I adjusted the entity settings in Home Assistant to hide the non-functional ones. It’s a minor tweak, but it made a big difference in usability.
Testing and Fine-Tuning
After setting up the Hue Bridge and resolving the Fibaro issues, I did a thorough test of my Zigbee network. I monitored the signal strength of all devices and was happy to see that the previously problematic areas now had stable connections. I also set up a routine where the lights dim when there’s no motion detected, which has been working flawlessly.
Tips for Others
If you’re dealing with similar issues, here are a few tips:
- Invest in a Good Zigbee Repeater: It’s worth the investment to ensure reliable communication across your entire home.
- Check for Duplicate Entities: If you’re using devices like the Fibaro Dimmer, make sure to review and clean up your entity list in Home Assistant.
- Regular Network Scans: Use the network scan feature in Home Assistant to keep track of your Zigbee devices and their statuses.
Overall, these fixes have made my Zigbee setup much more reliable and enjoyable to use. It’s amazing how a few adjustments can make such a big difference! If anyone has questions or needs advice on similar issues, feel free to reach out. Happy automating everyone! ![]()
