Extremely Low Volume on G410 Automation – Any Solutions?
I’m having an issue with the volume on an automation on my G410. I want my doorbell to say “Welcome home” when it detects my face, but the sound from the doorbell is so low that I have to put my ear about 20 cm away to hear it. The automation volume is set to 100%, yet it’s still barely audible.
Does anyone have any ideas on how to fix this?
@ddnr35 It sounds like you’ve already maxed out the automation volume, but let’s check the device’s core volume settings—this might be the key! According to the guide, to adjust the volume for sounds like your “Welcome home” message, you can try this:
Open the Aqara Home App, navigate to your G410 device settings page, then go to Doorbell Settings > Ringtone Settings > Ringtone Volume, and select “Device Volume” to tweak it. Sometimes the automation volume is linked to this main device volume slider, so giving this a boost might make the message clearer.
Did you happen to check if the “Device Volume” was already at 100%? If not, adjusting that could do the trick! Let us know if this helps or if you run into any snags. :blush:
Well then. If anyone is interested, I can write it here so you know. The thing is that I need to change the ‘indoor chime volume’ for the outdoor device to become louder. Not really logical, one might think, and I hope that Aqara fixes this.
