Failed FP300 - One of two sensors dead
I was planning on switching to the FP300 as my go-to presence sensor and recently purchased / installed two. One works beautifully, the other stopped working 2-3 weeks into service. A 50% success rate is not desirable. Here’s the story for those that are interested.
Aqara FP300 failure description
The FP300 was switched to Zigbee mode and paired with a Hubitat C-7 using a community FP300 Zigbee driver. The device reports model lumi.sensor_occupy.agl8, firmware/version 0.0.0_6542, date code 20260515.
The sensor initially operated normally, including PIR and mmWave presence detection. It was installed approximately 30 ft from the Zigbee coordinator through two walls. There were no powered Zigbee routing devices between the sensor and coordinator, so the RF path may have been marginal.
After configuration, including setting detection distance and performing Spatial Learning, the sensor eventually stopped detecting/reporting presence correctly. PIR/mmWave behavior became abnormal and eventually there was no response to movement and no visible LED response.
I performed a factory reset using the 10-button-press procedure. After removing/reinstalling the batteries, the FP300 successfully paired with Hubitat again and initially worked normally. PIR detection, motion and room-state transitions all operated correctly after that reset.
The sensor was returned to its installation location and Spatial Learning/distance configuration was performed again. Approximately a day later it again stopped detecting presence normally.
I then moved the sensor close to the Hubitat coordinator to eliminate the original RF path as the immediate cause. The sensor still would not respond to movement and showed no LED response. However, it was not completely dead. At various times it still communicated over Zigbee: it returned successful bind/configure-reporting responses and responded to a manual Refresh with manufacturer/model information, temperature, humidity, illuminance and Aqara manufacturer-specific data.
Its communication subsequently became intermittent. One Refresh produced valid responses; a later Refresh produced no response.
I removed the battery carrier overnight. While completely unpowered, there were no messages from the sensor. After reinstalling the batteries, approximately 10 minutes later Hubitat received two Zigbee Device Announcements, followed by room-state, battery voltage, battery percentage, temperature and humidity reports. Therefore the sensor was still capable of booting and communicating over Zigbee even though the presence-sensing functions were not operating normally.
Both original CR2450 cells measured above 3 V individually with a DMM, and the loaded battery carrier measured approximately 3.01 V. To eliminate the batteries as a cause, I subsequently installed two new CR2450 batteries.
With the new batteries installed, the sensor still does not operate normally and I can now no longer obtain a factory reset using the 10-button-press procedure. There is no useful LED response.
A second FP300 with the same reported model/firmware is operating normally on the same Hubitat system.
I don’t know whether the original weak Zigbee path, Spatial Learning/distance configuration, firmware, or a hardware fault contributed to the failure. I mention those only because of the sequence of events; I cannot establish causation.
Amazon has already replaced the sensor and did not require the defective unit to be returned. I still have the failed FP300. If Aqara engineering would like the defective unit for examination, I would be happy to provide it.
What a great offer. I don’t know if these kinds of failures are common or the issue is known, but hope they consider this. I’m glad Amazon got you a replacement.
