I’m the proud owner of a few G5 Pro Ethernet cameras, which I’ve mounted outside my house. However, I’ve run into an issue with one location where the camera needs to be mounted on a side wall.
Because the mount doesn’t offer the full range of adjustment needed for that position, the image ends up sideways. As far as I can tell, the app only allows the image to be flipped upside down, rather than rotated by 90°. This means I have to turn my phone sideways to view the image in the correct orientation.
I’d love to see an option in the app to rotate the image by 90° in either direction. Has anyone else run into this issue? If so, how have you solved it?
I know a different mounting arrangement, such as an L-bracket, could help, but being able to adjust the image orientation directly in the app would be the simplest solution for my setup.
Hi @shaffy248
Mounts can be 3D-printed; there are many options available online for this camera, catering to all kinds of use cases. An updated bracket was planned for release, but I haven’t seen it on sale yet.
Would you want the 90° rotation applied only to live view, or also to saved clips and streams shared with other apps? That distinction seems worth adding to the request, along with what should happen to detection-zone coordinates. I haven’t tested sideways AI detection, so I’d keep that limitation separate from the display-orientation request.
