Feature Request: Virtual Switches / Timers exported to Matter & HomeKit (Hub M3)
Hi everyone and Aqara team,
I would like to suggest a feature for the Hub M3: the ability to create Virtual Accessories directly within the Aqara Home app (such as virtual switches, toggle buttons, or countdown timers) that can be exposed to third-party ecosystems like HomeKit, Google Home, or Alexa via Matter / HomeKit integration.
Use Case: Currently, when setting up cross-platform automations or advanced local routines, there is often a need for a dummy/virtual switch or a timed helper to act as a trigger, state holder, or delayed action bridge between Aqara and HomeKit.
Having native virtual devices on the Hub M3 would allow us to:
  • Trigger HomeKit scenes or devices directly from Aqara automations without needing extra physical hardware.
  • Store states or countdown conditions to bridge logic between ecosystems natively.
This feature is already standard on some other platforms and adding it to the Hub M3 would make it an even more powerful central hub for smart home setups.
Would love to hear if others in the community find this useful, and hopefully the development team can consider it for a future firmware update!
Thanks!
Is there a specific use-case you are trying to solve right now?
The feature “Matter Scene and Signal Sync” works wonders for bridging ecosystems. Have you played with this at all? I’m just curious if what you’re hoping to accomplish could be solved there.
If you’re use-case is just to have virtual switches for triggers and conditions like you can do with Home Assistant or Homebridge the request might be too generic.
Hi! Thanks for the quick reply and feedback!
To explain better, while Matter Scene and Signal Sync works fine for one-shot actions, it doesn’t cover two very common needs that I’m trying to solve:
  1. **Reliable Countdown Timers and Auto-Off Logic:**Apple HomeKit is notoriously unreliable and limited when handling dynamic countdown timers (like keeping a light on for X minutes after motion and resetting the timer if new motion is detected). Since I consider the M3 Hub a very powerful hardware local engine, having a native timed virtual switch running directly on it would be the ideal solution. The M3 would handle the countdown logic locally and rock-solid, simply exposing the result to HomeKit.
  2. **State Flags for Automations (ON/OFF Conditions):**In my setup, my switches are not Aqara (they are BTicino and exposed only to HomeKit). A Matter Scene sends an instant push signal, but it doesn’t hold a state. I need a virtual switch on the M3 to act as a toggle (like “Guest Mode” or “Vacation Mode”) so HomeKit can check if it is ON or OFF as a condition before running an automation.
So in short, scenes are great for momentary triggers, but virtual accessories are needed when you want to handle timers locally on a powerful hub like the M3 or store an ON/OFF state across ecosystems without needing physical workaround hardware.
Hope this makes sense
Yep - makes sense. Very common use case for virtual switches in Homebridge and Home Assistant. So your ask is just t have that functionality inside Aqara to eliminate the need of extra systems.
Hi, this is a sore point for the Aqara app as well. A virtual switch is the solution to many automation challenges. I covered virtual switches in my tutorial: Automation 2.0, lesson 12, blitz topic, VIRTUAL Aqara switch. I also submitted suggestions for the development of the new version of the app—let’s see what comes of it.
I also thought about using an automation as a virtual switch, but he wants to read the switch’s status in Apple Home, and that doesn’t work, does it?
The only workaround I can think of is Shortcuts, because you can save content globally there and then read it in “if” conditions. However, those run on the iPhone and not on the hub, so they’d also be unsuitable for vacation mode and similar features.
That leaves only a smart plug with no devices connected to it that can be integrated into Apple and Aqara. Or, as already mentioned, Home Assistant (Helpers → Create Toggle).
You’re right ! You summarized why the current workarounds aren’t ideal.
Using a physical smart plug with nothing plugged into it just to act as a logic flag works, but having to buy extra hardware for a simple software function feels unnecessary—especially on a powerful hub like the M3. And running iOS shortcuts breaks central home logic for the rest of the family or when away from home.
It’s also really encouraging to hear from @gafich10 that this has been forwarded to the developers for consideration in future app versions! Having native Virtual Accessories / Helpers on the M3 Hub would be a huge improvement to keep automations clean, fully local, and reliable without workarounds.
Thanks again everyone for discussing this and supporting the idea!
Hope to see it in action soon!
