Hello Aqara Team,
I am writing to provide feedback on the new Spatial Multi-Sensor FP400. I am currently using one FP400 alongside two FP2 sensors to cover a single area (“Hallway²”).
I am using the “Connect to Ecosystem” feature via Matter to combine these sensors into one softsensor, but the FP400 does not seem to trigger correctly alongside the FP2s. This makes it difficult to create reliable automations for the shared space.
Could you please look into the sync reliability between the FP2 and FP400 when combined via Matter in a future update?
Thank You!
@KevinStarks Thanks for the detailed feedback on combining the FP400 with your FP2 sensors via Matter — that’s a really interesting multi-sensor setup for your “Hallway²” space! I can see how frustrating it must be when the FP400 doesn’t trigger in sync with the FP2s, especially when you’re trying to build reliable automations across a shared zone.
A couple of quick thoughts from the community side: the FP2 itself doesn’t currently support Matter natively, so there may be some inherent complexity in how these two sensors bridge into the same Matter fabric. The FP400 (or FP300) uses Thread/Zigbee dual-protocol, while the FP2 relies on Wi-Fi — that difference in underlying connectivity could contribute to sync inconsistencies when merged into a single softsensor.
Since this involves Matter ecosystem integration behavior and potential firmware-level coordination between product lines, I’d definitely recommend flagging this directly with the Aqara team so they can log it properly.
Contact the Aqara Home App Customer Service Team (Profile > Help & Feedback > Customer Service) or scan the QR code:
This will be more efficient. If you do not have an Aqara Home account, please
click here to create a ticket.
Appreciate you sharing this real-world use case — multi-sensor fusion for larger spaces is definitely an area where more polish could help the whole community
Hello, can you describe the function you want to achieve in more detail and what specific situation you mean by not trying to trigger is that the trigger is not successful?
Judging from your current automation conditions, I understand that you want to give a signal of someone as long as one of these sensors triggers someone, right? So under what conditions can it not be triggered correctly now? It may be helpful to look at the logs of specific devices to see which device did not trigger the state you want correctly, and then you can analyze the causes more specifically.
I tried merging three zones from three different sensors into one using soft sensors via matter, which I achieved with three FP2 units. After upgrading one FP2 to an FP400, the combination no longer functions properly with the FP400.
If you can provide specific logs and scenes that don’t work, it may be more helpful to analyze the reasons and countermeasures.
I am trying to merge three overlapping physical areas—the Front Room, Bedroom, and Entryway—into a single, unified ‘Hallway²’ zone.
My current setup includes two Aqara FP2 sensors (paired to Homey Pro via the HomeKit Controller) and one Aqara FP400 (paired via Matter through an M300 hub). Because individual sensor placement leaves blind spots in the hallway, I am using the Aqara app’s ‘Connect to Ecosystem’ feature to combine these three weak zones into one strong virtual zone.
While this Matter sync worked flawlessly when I was using three identical FP2 units, it consistently fails now that I have substituted one FP2 for the newer FP400. It appears the mixed payload types between the older FP2 and the newer FP400 are preventing the unified signal from bridging correctly.
