FHT80b Time Programming Without Constant PC Usage
Hello everyone! I’ve been using several FHT80b thermostats with radiator actuators and window contacts in my home, and I’m quite satisfied with their performance. However, I’ve noticed that making adjustments to their settings isn’t as straightforward as I’d like. Every time there’s a change in schedule or a need to adjust the programming, I have to manually go through each room and thermostat, which can be quite time-consuming.
I’ve heard about the FHZ 1000 PC or 1300 devices and wonder if they could be used solely for programming purposes without requiring the PC to run constantly. The FHT80b thermostats seem capable of handling the regulation on their own, so it would be ideal if the PC only needed to be active during programming sessions.
My main concern is whether this setup would work seamlessly, allowing me to reprogram the thermostats and adjust their time settings without the PC needing to be on all the time. Any insights or experiences others might have with similar setups would be greatly appreciated!
Looking forward to hearing your thoughts and tips! :blush:
