Fibaro Button Review and Integration Experience
I recently purchased the Fibaro Button after being intrigued by its sleek design and potential for smart home integration. The packaging was impressive, as mentioned in the manual, with a double-sided sticker for easy placement. The button itself is surprisingly small, measuring 30mm in height and 46mm in width/depth, which made me cautious about handling it too roughly.
The setup process was straightforward. I used the Home app to scan the QR code, and it paired seamlessly. The button supports single, double, and long presses, which I configured to control my lights. For instance, a single press turns them on, a double press turns them off, and a long press changes them to red. This customization added a personal touch to my smart home setup.
One feature I particularly appreciated was the battery life. According to Fibaro, it should last about two years with regular use, which is a significant advantage for a device that’s always on standby. The battery compartment is easily accessible by twisting the button anti-clockwise, making replacements a breeze.
However, I encountered a minor issue with the color options. While Fibaro claims there are 8 colors available for the HomeKit version, I only found black, white, and red in the official store. This was a slight disappointment, but the button’s functionality made up for it.
The button’s Bluetooth performance was another highlight. Despite the signal strength app indicating less than ideal conditions, the button responded almost instantly. This reliability is crucial for a device meant to be a quick control solution.
For anyone considering the Fibaro Button, I recommend exploring the configuration options thoroughly. The ability to assign different actions to each press type makes it versatile for various smart home scenarios. It’s a testament to Fibaro’s attention to detail and user-centric design.
Overall, the Fibaro Button has been a valuable addition to my smart home setup. Its ease of use, customization options, and reliability make it a worthwhile investment. If you’re looking for a discrete yet powerful control solution, I highly recommend giving this button a try.
