I recently encountered an issue while trying to set up a Fibaro button on my Homey 2023 system. Despite following the standard pairing procedure, the button wasn’t being recognized by Homey. This was quite puzzling, as I expected the setup to be straightforward. After some research and reaching out to the community, I discovered that others had faced similar challenges. Some suggested issues with Homey’s firmware compatibility with older devices, while others pointed to potential errors in the pairing process itself. To resolve this, I decided to explore different methods and consult user forums for guidance. One helpful tip was to ensure the button was in the correct pairing mode, which might require holding the button for several seconds or performing specific actions during the setup. After multiple attempts and following the advice from the community, I finally succeeded in pairing the Fibaro button with Homey 2023. This experience underscored the importance of perseverance and the value of community support in troubleshooting such issues.
