Fibaro Dimmer 2 and ESP32-Camera Doorbell Integration Tips
Hi everyone! I’ve been diving into some exciting home automation projects lately and wanted to share my experiences and tips in case they can help others. Let me start by talking about my recent setup with the Fibaro Dimmer 2 and my ESP32-Camera doorbell project.
First off, I installed a Fibaro Dimmer 2 to control my ceiling lights. I was initially confused about how to use the momentary switch for dimming. After some research and experimentation, I figured out that while the manual mentions holding the switch to set brightness to 1% or 99%, there’s a workaround to achieve intermediate brightness levels. By using a combination of double-clicks and timed presses, I can now smoothly adjust the lighting to my desired level. It’s a bit of a hack, but it works perfectly!
Moving on to my ESP32-Camera doorbell project, I’ve been absolutely thrilled with the results. I designed a custom enclosure for it using my 3D printer, which not only looks sleek but also adds a functional button for visitors. The integration with my home automation system has been seamless. When someone presses the button, it triggers a snapshot, plays a chime on my entrance media player, and sends notifications to my phone. I even added night vision using IR LEDs, which has been a lifesaver.
One thing I’d like to mention is the importance of proper configuration. I spent some time tweaking the ESPHome YAML code to ensure everything worked smoothly. It’s a bit daunting at first, but breaking it down into smaller parts made it manageable. I also recommend checking out the ESPHome community for tips and troubleshooting help.
For anyone looking to tackle similar projects, my advice is to plan thoroughly, test each component individually before integrating, and don’t hesitate to reach out to the community for support. It’s amazing how much you can achieve with a bit of creativity and persistence!
I’d love to hear about your experiences with Fibaro dimmers, ESP32-Cameras, or any other automation projects you’ve undertaken. Feel free to share your tips, tricks, or even the challenges you’ve overcome. Let’s keep the learning and sharing going!
Cheers and happy automating! :slight_smile:
