I recently purchased a Vera Plus and decided to integrate my existing Fibaro Dimmer 2 into my smart home setup. However, I’ve encountered an issue where the device periodically stops responding and then regains connection without any apparent reason. This behavior is quite frustrating, especially since the device worked perfectly fine before.
I’ve tried troubleshooting by checking the distance from the hub, resetting the device, and ensuring the firmware is up-to-date. Despite these efforts, the problem persists. It’s definitely not a distance issue, as the device is only a few meters away from the hub.
I’m reaching out to the community to see if anyone else has experienced similar issues with the Fibaro Dimmer 2 or has any suggestions on how to resolve this. Any advice or insights would be greatly appreciated!
- Distance Check: Confirmed the device is within optimal range.
- Reset Attempts: Restarted the device multiple times without success.
- Firmware Update: Ensured the device is running the latest firmware version.
If anyone has encountered and resolved this issue, please share your experience. I’m eager to find a reliable solution to ensure smooth operation of my smart home setup.
