I recently decided to upgrade my living room lighting setup to something smarter, and I thought the Fibaro Dimmer 2 (212) would be the perfect addition. However, my journey wasn’t without its bumps, and I wanted to share my experiences and tips in case anyone else is going through a similar process.
The Setup Challenge
I have a ceiling lamp that’s powered through a 13A socket in the garage, currently using a timer socket. My goal was to replace this with a smart setup. After reviewing the wiring diagrams, I realized I didn’t have a traditional switch, which simplified things a bit. I followed the wiring instructions for the Fibaro Dimmer 2, connecting it directly in the ceiling. At first glance, it seemed straightforward, but I quickly ran into some issues.
LED Compatibility and Wattage Concerns
My lamps are non-dimmable LED bulbs, which I later found out could be problematic. The Fibaro Dimmer 2 has a minimum wattage requirement of 50W, and my setup only draws about 10W. This led me to consider the Dimmer Bypass 2, but then I discovered that it’s only compatible with dimmable lamps. This was a bit of a setback, but I didn’t give up!
Transformer and 12V Setup
Since my bulbs are 12V, I had to treat the transformer as the lamp in my setup. I was worried about how the Fibaro Dimmer 2’s test cycle might affect the transformer, but after some research and testing, I found that it worked without issues. I also realized that I could bypass the need for the Bypass 2 by upgrading my LED bulbs to meet the minimum wattage requirement.
Lessons Learned
- Check Compatibility First: Always verify if your devices are compatible with the hardware you’re planning to use. LED bulbs can be tricky, especially with dimming and bypass requirements.
- Understand Your Wattage Needs: If your setup doesn’t meet the minimum wattage requirements, consider upgrading your bulbs or finding alternative solutions.
- Transformer Considerations: If you’re using low-voltage bulbs, treat the transformer as part of your lamp setup and test it thoroughly to avoid any issues.
- Read Manufacturer Guidelines: Vesternet’s specifications were crucial in helping me understand the limitations and requirements of the Fibaro Dimmer 2.
While the process was a bit frustrating at times, it taught me a lot about smart lighting setups and compatibility issues. I’m now enjoying a fully functional smart lamp system, and I feel more confident tackling similar projects in the future. If anyone has questions or needs advice, feel free to reach out—I’m happy to help!
Happy smart home tinkering! ![]()
