Fibaro Door Sensor 2 Integration Issues in HomeAssistant
Hello, I’m currently facing an issue with integrating my Fibaro Door Sensor 2 into HomeAssistant using Zwave (Zwave2MQTT). The sensor appears in Home Assistant as ‘Unknown’, and I’m unable to resolve this despite configuring the OZW settings. Here’s what I’ve tried so far:
  1. OZW Configuration: I’ve set up the sensor in OZW, but the values are still showing as ‘Unknown’. The debug output doesn’t provide any clear errors or solutions.
  2. Entity Configuration: The entity in HomeAssistant shows the sensor as ‘Unknown’ with no meaningful data. The configuration seems correct, but the state isn’t updating properly.
  3. Debugging Attempts: I’ve reviewed the OZW debug logs and the entity configuration, but nothing stands out as a clear issue. The sensor is recognized but not providing useful data.
I suspect the problem lies within the OZW configuration, but I’m not entirely sure how to proceed. Has anyone encountered a similar issue or has a solution they can share? Any guidance would be greatly appreciated!
