I wanted to share my positive experience with the Fibaro FGD-211 dimmer, especially when paired with Philips MASTER LEDspot MV 5.5w GU10 bulbs. After experimenting with cheaper LED options in the past, I consistently faced flickering issues, which were both frustrating and disruptive. However, with the Fibaro dimmer, I’ve found a reliable solution that not only enhances my lighting setup but also ensures smooth operation without any hiccups.
Initially, I set up two Fibaro FGD-211 units—one controlling four bulbs and the other managing eight. The installation process was straightforward, and the dimmer’s default settings worked seamlessly out of the box. However, I wanted to explore the full potential of the device to achieve a wider dimming range. After some research and experimentation, I adjusted the settings to:
- Variable 20: 110
- Variable 12: 60
- Variable 13: 2
This configuration allowed me to achieve a full dimming range from 10% to 100%, eliminating any issues with the lights turning off prematurely at lower settings. The Philips bulbs, known for their quality, paired perfectly with the Fibaro dimmer, delivering consistent performance and a pleasant user experience.
I’m particularly impressed with how the Fibaro dimmer handles the load without introducing any flickering, even at the lower end of the dimming spectrum. This has been a game-changer for my lighting setup, providing both functionality and aesthetic appeal. If you’re considering upgrading your lighting system, I highly recommend exploring the Fibaro FGD-211 dimmer—it’s a testament to quality and reliability.
