Hey everyone, I just wanted to share my experience with the Fibaro FGS-211 modules after adding them to my Vera system. At first, I was a bit puzzled because each module was creating two devices in the Vera UI5. I understand that this is related to the module’s dual functionality, but it was a bit overwhelming to see two entries for each switch. I did some research and found that hiding one of the devices through the startup LUA script was a potential solution. However, I ran into some issues where the device wouldn’t stay hidden despite no errors in the script. After some trial and error, I discovered that manually adjusting the settings within Vera’s interface was a more reliable method. I was able to successfully configure the module to show only one device, which now neatly integrates into my setup. It’s a great device once you get the hang of it, and it adds a nice touch of automation to my home. I hope this helps anyone else who might be experiencing similar confusion with their FGS-211 modules!
