As I was setting up my smart home system, I came across an interesting challenge with the Fibaro FGS211 modules. After adding one module, I noticed that Vera UI5 was showing two devices instead of just one. At first, I was a bit puzzled and a little frustrated, but after some research and troubleshooting, I found a solution that worked perfectly for me. Here’s how I resolved the issue and optimized my setup:
Understanding the Issue
The FGS211 module has a single output, but Vera UI5 was listing it as two separate devices. This duplication wasn’t ideal, especially since I wanted a clean and organized interface. I tried hiding one of the devices, but it didn’t work as expected. After some digging, I realized that this behavior is a known quirk with the FGS211 module.
The Solution
Instead of trying to force Vera to show only one device, I focused on configuring the module to work seamlessly with my existing setup. Here’s what I did:
- Manual Configuration: I manually set up the module in Vera UI5, ensuring that it was recognized as a single device. This involved tweaking some settings and using Vera’s advanced configuration tools.
- Lua Scripting: I utilized a Lua script to streamline the automation process. This script ensured that the module operated smoothly without any unnecessary duplication.
- Custom Rules: I created custom rules within Vera to manage the module’s output effectively. This approach allowed me to control the module’s behavior precisely, eliminating any confusion caused by the duplication.
Tips for Others
If you’re encountering similar issues with your Fibaro modules, here are a few tips to help you out:
- Check Documentation: Always refer to the official documentation for your devices. It’s a goldmine of information and can save you a lot of time.
- Community Support: Don’t hesitate to reach out to forums and communities like this one. You’ll find a wealth of knowledge and support from other users who have faced similar challenges.
- Experiment: Don’t be afraid to experiment with different configurations and scripts. Trial and error can lead to some surprising breakthroughs!
While the initial issue with the FGS211 module was a bit frustrating, it turned out to be a great learning opportunity. By taking the time to understand the problem and explore different solutions, I was able to optimize my setup and make it work perfectly for my needs. If you’re facing similar challenges, remember to stay patient and keep experimenting—you’ll find a solution that works for you!
Happy automating! ![]()
