Hi everyone, I’ve recently started using Home Assistant after switching from Jeedom, and I’m encountering an issue with the Fibaro FGT-001 heat controller. I’m trying to set a specific parameter to enable additional features, but it seems like the value isn’t being applied correctly. The parameter should accept values like 1, 2, 3, etc., but whenever I try to set it, it stays at the default value of 1. I’ve included some logs below for reference:
2019-11-16 22:07:22.512 Info, Node010, Value::Set - COMMAND_CLASS_CONFIGURATION - Additional functions - 2 - 1 - 31
2019-11-16 22:07:22.512 Info, Node010, Configuration::Set - Parameter=2, Value=31 Size=4
… (more log entries) …
2019-11-16 22:07:33.807 Error, Node010, ERROR: Dropping command, expected response not received after 1 attempt(s)
I’ve tried restarting the device and checking the network settings, but the issue persists. The product works perfectly with other domotic solutions, so I’m hopeful it can be resolved here too. Any advice or suggestions would be greatly appreciated! Thanks in advance for your help.
