Recently, I decided to enhance my home’s security by investing in the Fibaro Flood Sensor. After setting it up, I must say, it’s been a game-changer for me. The installation process was straightforward, thanks to the clear instructions provided. The sensor comes with a custom-sized battery, which makes it easy to get started without any hassle.
One of the standout features of this device is its dual functionality—it not only detects water but also monitors temperature. This dual capability adds an extra layer of security, especially in areas prone to moisture or temperature fluctuations. The sensor also includes a tamper detection feature, which sends an alert if the device is moved or interfered with. While this doesn’t appear as a separate tile in the Home app, it’s a reassuring added security measure.
The Fibaro Flood Sensor integrates seamlessly with my existing HomeKit setup. It appears as two devices in the Home app: one for flood detection and another for temperature monitoring. This makes it easy to manage and customize within the app. The sensor’s notifications are prompt and reliable, providing immediate alerts on my iOS devices whenever water is detected.
I was particularly impressed by the sensor’s size. While I initially thought it might be too small, it turned out to be perfectly sized for my needs. The packaging was professional, and the included manuals were comprehensive, ensuring a smooth setup process.
For anyone considering this sensor, I recommend placing it in areas where water damage is a concern, such as basements or near plumbing fixtures. Its compact design allows for discreet placement without compromising on functionality.
Overall, the Fibaro Flood Sensor has been a reliable addition to my smart home setup. It provides peace of mind knowing that my home is protected against potential water damage. If you’re looking for a dependable flood detection solution, I highly recommend giving this sensor a try.
