As a homeowner in a cold climate, I’ve been searching for a reliable outdoor motion sensor that can withstand freezing temperatures without draining battery life. After some research, I decided to go with the Fibaro FGMS-001 motion sensor. While it’s technically an indoor sensor, I wanted to use it outdoors, so I needed to find a suitable housing solution.
I came across the Spelsberg outdoor box TG ABS 88-6-to, which seemed perfect for the job. The box required some modifications, including drilling a 30mm hole for the sensor and adding a rubber ring for water resistance. I also glued the sensor bracket to the base of the box using power strips to ensure stability.
The installation process was a bit tricky, especially getting the sensor aligned properly, but the result has been fantastic. Despite temperatures dropping to -1°C, the sensor has been working flawlessly. I’ve been running two of these modified devices for several months now, and they consistently detect motion without any issues.
I highly recommend this setup to anyone looking for an energy-efficient outdoor motion sensor that can handle harsh weather conditions. The combination of the Fibaro sensor and the Spelsberg box provides both reliability and durability, making it a great investment for home security.
If you’re considering a similar project, here are some tips:
- Measure carefully before drilling to ensure the sensor fits perfectly.
- Use a strong adhesive like cyanocrylate glue for the rubber ring to ensure water resistance.
- Don’t be afraid to add multiple layers of adhesive to get the sensor height just right.
This setup has been a game-changer for my outdoor security needs, and I’m happy to share my experience to help others achieve the same success!
