Hello everyone, I’m reaching out for some expert advice on adjusting the temperature reporting threshold on my Fibaro FGMS-001 sensors. While the sensors are functioning correctly, I’ve noticed that they only trigger updates when the temperature changes by more than 1 degree Celsius. This isn’t ideal for my setup, where I need more frequent readings.
From what I’ve gathered, there’s a parameter called “TEMPERATURE REPORT THRESHOLD” (Parameter Number 60) that controls this behavior. I believe this parameter determines how much the temperature needs to change before a report is sent. My goal is to adjust this threshold to 0.5 degrees Celsius to get more granular data.
I’ve checked the Vera Support team, and they confirmed that this parameter exists, but I’m not entirely sure how to read its current value or change it. If anyone has experience with this or can provide step-by-step instructions, I’d greatly appreciate it!
This adjustment would make a significant difference in how I monitor temperature changes in my smart home setup. Thank you in advance for your help and insights!
