I’ve been exploring the Fibaro Smart Implant for my home automation setup, and I must say, it’s been an interesting journey. The ability to use two inputs as contact sensors and two outputs as switches independently is a fantastic feature, especially for channel 1. However, I ran into a snag with channel 2—it wouldn’t disconnect properly. Whenever IN 1 received input, it triggered OUT 2 to turn on, which wasn’t the intended behavior. After some research, I suspect there might be an issue with the driver settings. I’ve shared my configuration below, and I’m curious if anyone else has experienced similar challenges or found a workaround. Additionally, if someone knows where to find the original driver code, that would be incredibly helpful. Thanks in advance for your insights and support!
