Fibaro Smoke Detector Connection Issues and Solutions
I recently purchased two Fibaro smoke detectors and decided to set them up in my home. The process seemed straightforward initially, but I encountered a few unexpected hurdles that made me scratch my head. Let me share my experience and the solution I found, in case it helps others facing similar issues.
First, I tried connecting the first smoke detector. Unfortunately, it didn’t work on the first attempt. I retried, and this time, I received a message saying “Status: Already Added.” However, I couldn’t see the device in my list of connected devices. Frustrated but determined, I moved on to the second detector, which connected without any issues. I restarted my Homey and reinstalled the Fibaro app, but the problem with the first detector persisted.
After some research and reaching out to the community, I discovered that Fibaro devices sometimes get stuck in a “already added” state. The solution was to make the system forget the problematic device so I could reinstall it properly. I found a guide that walked me through the process of resetting the device and ensuring it was completely removed from the system before attempting the installation again.
Following the guide, I was able to resolve the issue, and now both smoke detectors are working perfectly. It was a bit of a journey, but it taught me the importance of community support and the value of persistence when troubleshooting smart home devices.
If anyone else is experiencing similar issues with Fibaro devices, I highly recommend checking out the detailed guides available in the community forums. Sometimes, a fresh perspective and step-by-step instructions can make all the difference!
