Fibaro vs Aeotec TRVs: A Comprehensive Comparison and Experience
I’ve been using the Aeotec TRV with my Vera hub for quite some time now, and while it works adequately, there are a few quirks that have been bugging me. The main issue I’ve encountered is the valve’s feedback status. When I set the temperature to off, the valve remains open, which sometimes causes the radiator to overheat, especially in rooms where the temperature can easily spike above 23 degrees. I’ve read online that this is a known issue, and some users have even returned their Aeotec TRVs due to this problem.
This experience has led me to consider switching to the Fibaro TRV. However, I have a crucial question: does the Fibaro TRV report back the room temperature automatically, or is an additional temperature device required? I’ve noticed that the Aeotec TRV updates the Vera hub with the current temperature without any issues, so I’m curious to know if the Fibaro TRV operates similarly.
Another aspect I’m exploring is the integration of the Northfifteen Connected Home Plant Monitor, which is essentially a rebranded Mi Flora sensor. Unfortunately, it doesn’t broadcast temperature or moisture data as the Mi Flora does, making it incompatible with espHome. I’ve tried various methods, including spoofing GPS locations and using a VPN to update the firmware, but it hasn’t worked out. This has been quite frustrating, as I was really hoping to use this device with my Home Assistant setup through esp32.
On a more positive note, I’ve been experimenting with Enerwave dimmer and on/off switches. They support instant status and associations, which is a huge plus compared to the Jasco switches I’ve used in the past. While the Vera interface isn’t perfect, they function as described, and I feel they offer great value at around $45 US. I’m definitely considering purchasing more of these for my setup.
I’d love to hear from anyone who has experience with these devices or has found a workaround for the Northfifteen Plant Monitor issue. Your insights and experiences would be invaluable!
