Fibaro Walli Dimmer Brightness Adjustment Tips
Hello everyone, I wanted to share my experience with adjusting the brightness of the Fibaro Walli Dimmer, especially when integrating it with Homey. I recently added a few devices to my setup, and one of my main goals was to have the lights dim slightly at night for a more comfortable ambience. However, this turned out to be a bit more challenging than I initially thought.
The Challenge
I started by exploring the settings within Homey, hoping to find a straightforward way to adjust the brightness. Unfortunately, I discovered that the Fibaro Walli Dimmer doesn’t support the “Force Brightness” feature mentioned in its manual. This meant I couldn’t directly set a specific brightness level through the app. I also tried creating flows with variables to store the desired brightness, but this approach had a noticeable delay—something that’s particularly frustrating when you’re trying to navigate in the dark.
The Solution
After some trial and error, I found a workaround that works well for my setup. Instead of relying solely on flows, I combined a few settings within Homey to achieve the desired effect. Here’s how I did it:
- Scheduled Dimming: I set up a schedule that automatically dims the lights to my preferred brightness at sunset. This ensures that the lights are already at the correct level when I turn them on manually later in the evening.
- Instant Adjustment: For immediate adjustments, I created a simple flow that changes the brightness without waiting for a transition. This allows me to quickly tweak the lighting if needed.
- Combining Flows: By combining these two approaches, I was able to eliminate the delay issue. The lights now adjust smoothly and promptly, making the experience much more pleasant.
Tips for Others
If you’re facing similar challenges with your Fibaro Walli Dimmer or any other smart lighting device, here are a few tips:
- Experiment with Schedules: Automating brightness adjustments based on time can save you from manually tweaking settings.
- Use Flows Wisely: Flows can be a powerful tool for immediate changes, especially when combined with other automation rules.
- Check for Firmware Updates: Sometimes, issues like these can be resolved with a simple firmware update. Make sure your devices are always up to date.
I hope this helps someone who’s struggling with similar issues. Let me know if you have any questions or if there’s a better way to achieve this! ![]()
Happy automating!
