Hey everyone! I wanted to share my experience with integrating the Fibaro Window Shutter 2 into my smart home setup. While the process had its challenges, the end result has been absolutely worth it!
Starting off, I initially struggled with getting the shutter to work seamlessly with my Home Assistant setup. The device was publishing correctly on my MQTT broker, but controlling it through HA wasn’t as straightforward as I hoped. After some research, I realized that the issue stemmed from the way Home Assistant handles cover commands. Instead of sending numerical values, it was sending commands like ‘OPEN’, ‘CLOSE’, and ‘STOP’, which didn’t align with how the Fibaro shutter expects commands.
To resolve this, I had to tweak my MQTT configuration. I adjusted the command and brightness topics to ensure they were sending the right kind of signals. Here’s a snippet of my working configuration:
yaml
cover:
- platform: mqtt
command_topic: “smartthings/Window Shutter/level”
brightness_command_topic: “smartthings/Window Shutter/level”
brightness_scale: 100
retain: true
This setup now allows me to control the shutter smoothly using percentage-based commands. For example, sending a value of 50 will position the shutter halfway open, which is perfect for adjusting natural light throughout the day.
Another thing I discovered was the importance of proper calibration. After installing the shutter, I spent some time fine-tuning its opening and closing limits to ensure it operates precisely as intended. This involved a few trial runs and adjusting the settings in the Fibaro app to get everything just right.
I’d also like to mention the benefits of using a smart hub like SmartThings. It acted as a reliable intermediary between my Fibaro devices and Home Assistant, making the integration process much smoother. Plus, having all my devices on a single hub has simplified managing my smart home ecosystem.
For anyone else looking to integrate Fibaro Window Shutters, my advice is to take it step by step. Start with a basic configuration, test each command, and then gradually refine your setup based on how the shutter responds. It’s also worth checking out the community forums for additional tips and troubleshooting advice—there’s a wealth of knowledge out there!
Overall, I’m really happy with how this integration turned out. It’s added a whole new level of convenience and automation to my home, and I can’t recommend it enough to others looking to enhance their window controls!
Cheers,
Gil
