I recently explored the possibility of detecting file creation in OpenHAB, specifically for triggering actions like notifications or switching lights when motion is detected by my Xiaomi camera integrated with Synology Surveillance Station. Here’s my journey and insights:
The Challenge:
Initially, I faced difficulties in getting real-time motion detection data directly from the surveillance station. The workaround I considered was leveraging file creation events on my Synology NAS, where motion-triggered videos are stored. This approach seemed promising but required some tweaking.
The Solution:
After researching, I discovered that OpenHAB can monitor file system events using the FileSystem binding. By setting up a rule to watch the specific folder where motion videos are saved, I could trigger desired actions whenever a new file (indicating motion) is detected.
Implementation Steps:
- Configure the FileSystem Binding: I added the necessary configuration to monitor the target folder.
- Create an OpenHAB Rule: Using the Rule Editor, I wrote a rule that checks for new files in the specified directory and sends a notification or activates a virtual switch when a new file is detected.
- Testing and Fine-Tuning: I tested the setup thoroughly to ensure it works reliably without false triggers.
Benefits and Learnings:
This setup has been incredibly effective. It not only provides real-time notifications but also integrates seamlessly with my existing smart home ecosystem. I learned the importance of exploring alternative methods when direct integrations aren’t feasible and how powerful OpenHAB can be with a bit of creativity.
Tips for Others:
- Ensure the folder path is correctly specified to avoid errors.
- Consider filtering file types to prevent unnecessary triggers (e.g., only monitor
.mp4files). - Use virtual switches for flexibility in triggering different actions.
I’m excited to see how this integration can be further enhanced and look forward to sharing more insights as I explore more features of OpenHAB!
