Fix Arlo Keypad Connectivity Issues: A Step-by-Step Guide
I came across a frustrating issue with my Arlo keypad disconnecting from Wi-Fi, leaving me without security coverage. This wasn’t a one-time glitch—it happened consistently, and neither Arlo support nor my internet provider could resolve it remotely. The keypad wouldn’t reconnect unless I was physically at home, which wasn’t ideal for someone who’s often away.
After some research, I discovered that my modem broadcasts three Wi-Fi bands: 2.4 GHz, 5.0 GHz, and 6.0 GHz, each under separate network names. Arlo devices require the 2.4 GHz band, but my keypad kept trying to connect to the others. I tried rebooting the modem and consolidating all bands under one network name, but the keypad still wouldn’t connect.
Finally, I found a workaround: I rebooted the modem again, splitting the bands back into separate networks. This time, the keypad reconnected successfully. It seems the keypad was having trouble handling the combined network setup. While this isn’t a permanent fix, it’s a reliable workaround for now.
This experience taught me the importance of understanding how different devices interact with Wi-Fi bands. If you’re facing similar issues, try experimenting with your network settings or reaching out to forums for community solutions. Stay vigilant and keep your home secure!
