Fixing Gray Images in Picture Cards
Hey everyone, I wanted to share a little challenge I faced recently and how I overcame it. Hopefully, this can help someone else out there!
So, I recently set up my home automation system and decided to create a waste collection schedule card. I thought it would be neat to include some images of the trash bins to make it visually appealing. I placed the images in the www folder and linked them in a picture-elements card. Everything seemed to be in order, but here’s the catch: one of the images was showing up as gray in the card, even though it displayed correctly when viewed directly in the folder. It was a bit puzzling!
I started by checking the syntax of my card configuration. I made sure the file paths were correct and that the entities were properly linked. I even tried replacing the image with a different one to see if the issue was with the specific file. Unfortunately, the problem persisted. I began to wonder if there was something wrong with the card setup itself.
After some research and trial and error, I stumbled upon a solution. It turned out that the image wasn’t being cached properly by the system. To fix this, I added a small delay in the card configuration using the delay parameter. This allowed the image to load correctly without being rendered gray. Here’s the adjusted configuration that worked for me:
  • type: image
    entity: sensor.gelbe_tonne
    image: local/Kunststoff.png
    delay: 1000
    style: pointer-events: none
    left: 15%
    top: 45%
    width: 20%
Adding the delay parameter gave the image enough time to load before the card rendered. It was a simple fix, but it made a world of difference!
I wanted to share this because it’s easy to get stuck on small issues like this. Sometimes, a little tweak can make all the difference. If anyone else is experiencing similar problems, I hope this helps you out!
Happy automating everyone! :blush:
