Hey everyone, I wanted to share my recent experience with my Zigbee network. I’ve been having trouble with a switch module in my bathroom that kept disconnecting. After some research, I discovered that the Low Quality Indicator (LQI) was quite low at 39, which I believe is not ideal.
I decided to try using a smart plug as a Zigbee repeater to boost the signal. I found one on AliExpress that works with Australian/New Zealand plugs, which was perfect for my setup. The installation was straightforward—just plug it in near the bathroom wall, and it started improving the connectivity almost immediately!
Here’s what I learned:
- Check LQI: If your device’s LQI is below 50, it might need a booster.
- Use Smart Plugs as Repeaters: They’re affordable and can significantly enhance your network coverage.
- Test Before Buying: If possible, test the repeater in different locations to find the optimal spot.
It’s been a week, and I haven’t had any disconnections yet. This fix has been a lifesaver! ![]()
