Hi everyone, I wanted to share my experience with Fluxer and how I finally managed to get it to auto-start on my Home Assistant setup. For those who might not be familiar, Fluxer is a fantastic tool that adjusts your lights based on sunrise and sunset times, offering a smooth transition from day to night. It’s been a game-changer for my home’s ambiance, especially during the changing seasons.
Initially, I set up Fluxer using the configuration.yml file, specifying the start_colortemp, sunset_colortemp, and stop_colortemp. I also added some customizations in the customize.yaml to make it more user-friendly. However, every time I restarted Home Assistant, Fluxer would be off, which was a bit frustrating. I tried various methods, including checking the configuration files, restarting the service, and even reinstalling the integration, but nothing seemed to work.
After some research and reaching out to the community, I discovered that the issue might be related to how Home Assistant handles auto-start for integrations. I came across a solution where you can force certain services to start by adding them to the homeassistant.yaml file. Here’s what I did:
Modify Configuration Files: I added a new section to my homeassistant.yaml file to ensure Fluxer starts automatically:
yaml
fluxer:
auto_start: true -
Restart Home Assistant: After saving the changes, I restarted Home Assistant to test if Fluxer would auto-start. To my delight, it worked perfectly! The lights now transition smoothly as the sun sets, and I don’t have to manually turn Fluxer on every time.
I wanted to share this solution in case anyone else is facing the same issue. It’s a small tweak but makes a big difference in the overall user experience. If you’re using Fluxer and haven’t tried this yet, I highly recommend giving it a shot. It’s been a real lifesaver for me!
Thanks to everyone in the community for their support and for sharing knowledge. It’s amazing how a small adjustment can make such a positive impact on our smart homes. Happy automating everyone! ![]()
