FM Radio Integration in Home Assistant - Success Story
Hey everyone, I wanted to share my recent success in integrating an FM radio into my Home Assistant setup. I’ve been tinkering with this idea for a while, and finally, it all came together! :notes:
I installed Home Assistant on my RV using Docker, and everything was running smoothly. The next step was to add some entertainment, so I decided to write a simple FM tuner app in C. The goal was to control the radio channels directly from Lovelace. Initially, I wasn’t sure how to proceed with the command line integration, but after some research and trial and error, I figured it out!
Here’s what I did: I set up buttons in Lovelace that trigger specific FM frequencies, like 94.9 FM and 103.1 FM. It’s super handy, and I even added an input field so I can tune in to any station on the go. The best part? It all works seamlessly within the Home Assistant interface. :headphones:
I’d love to hear if anyone else has tried something similar or has tips to make this integration even better. Maybe adding voice commands next? The possibilities are endless! :blush:
Cheers,
